12 years agoUsing CIC Decimation Filter with Multi-channel Support
Hi All, I have questions about this designe example: http://www.altera.com/support/examples/dsp-builder/exm-cic-decimation-filter.html I have attached the design files. In the file fir_c...
12 years ago --- Quote Start --- Hi Kaz, You mentioned "I and Q are interleaved at FIR output". What does interleaved mean? Does that mean there are two output channels for 35-bit I and 35-bit Q, respectively? Thanks, Lee --- Quote End --- Yes that is what I imagine as I-Q-I-Q-... you can check that by setting I input to zeros and Q to nonzeros
