16 years agoUsing Avalon ST packet transfer with SGDMA
Hi, I am creating a component between custom hardware and the SGDMA controller. The descriptors of the SGDMA are setup to transfer a large number of bytes at a time (24000 bytes) from the cus...
16 years agoIf you send less than 24000 bytes before the end of packet, the transfer will end if you enabled the "use start/end of packet" option (don't remember the exact name). You can also set the length to 0 to disable size check.
You should use burst transfer if you have a (DDR)SDRAM with a controller that supports it, and if you need the speed.
