14 years agouse descriptor chain in SGDMA
Hi all My current goal is to use SGDMA (ST-to-MM) to transfer video data to a memory. Later on, I'll replace the memory by PCIE IP. My problem is how to use descriptor chain in SGDMA. ...
13 years agoHi Hitesh,
I am now using modular SGDMA from Altera Wiki for my current project. So I may not able to help you in detail. You may check my attached zip file as an SGDMA example code. I'm not sure whether the example code is working but I was studying this code to understand Altera SGDMA.
