14 years agouse descriptor chain in SGDMA
Hi all My current goal is to use SGDMA (ST-to-MM) to transfer video data to a memory. Later on, I'll replace the memory by PCIE IP. My problem is how to use descriptor chain in SGDMA. ...
14 years agothe align attribute will ensure the different buffers will not end up o the same cache line, but there could still be some parts of video_buf that are cached and you can get the wrong contents.
Try to callalt_dcache_flush ((void*)video_buff,769*sizeof(alt_u32));before the SGDMA transfer. This will write down the cache contents to video_buff, but most importantly will invalidate the cache for this area. That way you will be sure the cache won't interfere with the data. AFAIK Altera doesn't provide a macro to just invalidate the cache without flushing it, even if the instruction exists in assembly.
