14 years agouse descriptor chain in SGDMA
Hi all My current goal is to use SGDMA (ST-to-MM) to transfer video data to a memory. Later on, I'll replace the memory by PCIE IP. My problem is how to use descriptor chain in SGDMA. ...
14 years agoHi Daixiwen
Thank you for the suggestions. My design works perfect when I use the function alt_uncached_malloc() to allocate two buffers. Correct data are printed out even if I access buffers without using IORD. By the way, I declare these two buffers outside all functions in my previous program so I think they are global variables. I guess using the global variables may not solve this problem.
