14 years agouse descriptor chain in SGDMA
Hi all My current goal is to use SGDMA (ST-to-MM) to transfer video data to a memory. Later on, I'll replace the memory by PCIE IP. My problem is how to use descriptor chain in SGDMA. ...
14 years agoHi dsl
In order to avoid the problem caused by cache data, I change my used NiosII CPU from NiosII/f to NiosII/e. I also try to set the 31th bit of the address or use tightly coupled memory in order to bypass the cache when I use NiosII/f. However, the problem is still the same. (I'm not sure what I've done with tightly coupled memory is correct. I do exactly the same thing as this document http://www.altera.com/literature/tt/tt_nios2_tightly_coupled_memory_tutorial.pdf) Anyway, I learn lots of things about how to bypass the cache data. Thank you.
