14 years agouse descriptor chain in SGDMA
Hi all My current goal is to use SGDMA (ST-to-MM) to transfer video data to a memory. Later on, I'll replace the memory by PCIE IP. My problem is how to use descriptor chain in SGDMA. ...
14 years agoHi Daixiwen
Thank you for the reply. I use an on-chip memory for storing the descriptor. The address of the on-chip memory is from 0x00040000 to 0x0004ffff. The Nios II (data_master) and SGDMA (descriptor_read and descriptor_write) are connected to the on-chip memory. I declare my descriptor table in the following code.
sgdma_desc = (alt_sgdma_descriptor*)ONCHIP_DESC_MEM_BASE;
ONCHIP_DESC_MEM_BASE is defined in system.h as follows:
# define ONCHIP_DESC_MEM_BASE 0x40000
For your last question, ("which memory is used for text, data, heap, stack and bss?") I don't know how to figure out these data in my program. Could you please give me some clues? Thanks.
