11 years agousage advanced blocks FFT blocks in project Standart blockset
1) I want to build a project using the HDL import, so I chose standart blockset. 2) I saw a working example of the combination of Standart and Advanced blockset - adapted_ad9856.mdl, and I want us...
11 years agoI solved all problems =) model works =)
I want to make the Fourier transform of the period of 8192 points. But I do not want all the 8192 coefficients, I will have enough and no more than 20. How i can get only first 20 and usage only 20 for retriving function, then improve performance and minimize the cost of memory for storing coefficients. Work model http://ge.tt/1vjrite2 - adaptedModelWithCordic.mdl
