16 years agoUrgent ! help please ! Pixel clock out from clocked video output core
Hello I am using the clocked video output core that will be connected to an LCD screen which needs from specification a pixel clock of 9 MHZ . I couldn't find out from the core such a clock , H...
16 years agoI have a similar requirement as the OP. Is the pixel clock simply passed from one IP block to another from the Clocked Video Input? Is the clock output of the CVI the clock that is on the input signal or is it generated by the CVI? If it is simply passed from the video decoder, I might have some troubles interfacing to my display as the clock is also limited to 9MHz.
