16 years agoUPSAMPLING BLOCK Problem
Hi guys, has anyone experiences with the DSP Builder "UPSAMPLING BLOCK" ??? I want to use it but there is one big Problem: The Up Sampling block increases the output sample rate from the input...
16 years agoNo, for my design I need an Up Sampling block with the feature I wrote. I know other tools where you have the option to say "Copy Samples". If I use for example a 5x Up Sampling block, the first cycle is high and the following four are zero, but I need the follwowing cycles as high as the first.
Got anyone an idea how to get this work?
