16 years agoUPSAMPLING BLOCK Problem
Hi guys, has anyone experiences with the DSP Builder "UPSAMPLING BLOCK" ??? I want to use it but there is one big Problem: The Up Sampling block increases the output sample rate from the input...
16 years agoThis is just what "upsampling" does. It pads zeros to increase the sampling rate. If you want to reconstruct the samples, a lowpass filter or bandpass filter is needed.
