11 years agoUniPHY DDR3 simulation is slow
I am using Modelsim to simulate a simple UniPHY DDR3 design and it takes ~10 minutes to finish the DDR3 calibration and assert the local_init_done signal. I did enable the Skip Calibration option in...
11 years ago --- Quote Start --- If you are getting a message like this from ModelSim:
# ** Warning: Design size of 31489 statements exceeds ModelSim Altera Starter recommended capacity.
# Expect performance to be adversely affected.
You should expect the simulation to be slow and the only way around it is to purchase a fully functional version of ModelSim. --- Quote End --- I am not seeing this or similar messages in the Modelsim transcript. My project is very basic. It contains one instance of the DDR3 IP and I am trying to do a simple write followed by a read. What performance should I expect with the Starter edition of Modelsim? According to this article at http://www.altera.com/literature/hb/external-memory/emi_debug.pdf, full calibration should take 10 minutes and Skip calibration should take 3 minutes. Since my simulation time is right around 10 minutes, I am suspecting that I am doing a full calibration for some reason. Is there a way to check if calibration is really skipped?
