15 years agoUndesired (incorrect?) behavour of CVI AV-ST output
Hi, I have a video stream (BT1120) entering an FPGA through the CVI. The stream can be interrupted at any time (someone pulling out the plug). I have an internally generated "blue-screen" that...
15 years agoHello Niki,
In my system the SDI IP is connected to the CVI. I had similar problems with source disconnection but I suspected the SDI core and not the CVI. Finally I have concluded to the exact solution as yours "single clock mode", this solution solved my problems (that I thought was SDI core problems). Now after I read your post I get a much better understanding, and I agree with your conclusions that this is CVI problem. I was working on version 10.1. Thank you for your detailed explanation. BR,
