15 years agoUndesired (incorrect?) behavour of CVI AV-ST output
Hi, I have a video stream (BT1120) entering an FPGA through the CVI. The stream can be interrupted at any time (someone pulling out the plug). I have an internally generated "blue-screen" that...
15 years agoHello,
Is the simulation that you have done is the simulation of your system with the Switch? I am asking this because the Switch behavior could be tricky to understand, so it is better to connect to the CVI a simpler component when checking it in simulation. BR,
