Unable to run example design for 25G ethernet IP for startix device(1SGO85HN2F4312VG)
Hi
I was running at Linux by using v19.3 and using the same script as you, everything looks fine. Today, I tested it in my window system with v20.4 (v19.3 is not available in my setup), and it is working fine as well. Since v19.3 was an older version, I would suggest you move to v20.4 or later, and if you still encounter the problem, we can debug from there.
Regards -SK
- Abhinav_behl5 years ago
Hi @SengKok_L_Intel ,
As per your suggestion, I have Quartus 20.4 installed on my laptop. When I try to run the script from Cygwin I am getting the same issue. I am attaching the screenshot for it. I am using intel FPGA ModelSim version 2019.2
To remove these error I breakdown the script and compiled in ModelSim. I was able to run the "com" command (which is for compiling files in the correct order(as per the script)). But when I try to run the "elab" command I am getting the same error as with the previous versions. I am attaching the transcript for the same( after running "elab").
Let me know if you require any other files.
Kindly help me I am stuck with this problem for a very long.
Abhinav Behl
