Unable to run example design for 25G ethernet IP for startix device(1SGO85HN2F4312VG)
Hi @SengKok_L_Intel,
I am also using the modelsim intel FPGA 2019.2 for Quartus v19.3, I am running using Cygwin command window but getting following error:
I have no idea how you are able to run the simulation for the 25G IP, can you share the details. The steps I am following are:
1. generate the example design from Quartus
2. GOTO directory/<example_testbench>
3. run "vsim -do run_vsim.do" command from cmd prompt.
I am also attaching permission of sim directory at which ModelSim is throwing error
- Abhinav_behl5 years ago
I was somehow managed to break the script into smaller scripts and was able to run the compilation, but after the compilation when I try to run the simulation I am still facing the error. I am attaching my transcript along in the attached section please review it.
