Unable to run example design for 25G ethernet IP for startix device(1SGO85HN2F4312VG)
What Quartus version that you are using? Could you please double-check if there is any permission (write enable) concern on your system?
Regards -SK Lim
Hi @SengKok_L_Intel,
Thanks for your prompt reply,
I am using Quartus 19.3. And yes I have double-checked write permissions, I am running it on windows and every permission is given to all files.
Yesterday I also tried one more thing to open the ModelSim GUI and add files manually and then compile using compile auto-generate option in ModelSim. In compilation also get errors. Apart from that when I try to run the simulation for top-level design, Modelsim exits with code 211 and the same message is printed in the .vstf file(to check vstf file I am told by ModelSim). For this step, I have attached the transcript file.
Please help me!
Abhinav Behl
