12 years agoTwo Avalon ST Interfaces comparison
Hello all, First, I'm sorry if this is not the right forum to post such question ! Second, I desperately need your help ! I'm trying to compare two avalon streaming interfaces (one outp...
12 years agoYou make it sound so easy !
I'm a bit confused myself ! what's the difference between instantiating the FIFO inside my component and outside it ? If I use the second technique ! What should I use as a reference sink ? the one output from the scaler I guess (because that's the PAL video source) ? The delay between the two frames can be half frame (not counting the first buffered frame) ! How can I eliminate that using just ready and valid signals ? I really appreciate your help Thank You
