12 years ago
Two Avalon ST Interfaces comparison
Hello all,
First, I'm sorry if this is not the right forum to post such question !
Second, I desperately need your help !
I'm trying to compare two avalon streaming interfaces (one output from a vip frame buffer and the other from a scaler) with the same resolution ! My problem is how to make my component receives both frames at the same time (make both startofpacket signals asserted at the same time) ? Logically the scaler source (or my custom component 1st sink) should control the other sink (from frame buffer) but I couldn't make that happen !
Any suggestion would be appreciated !
PS : Can I modify the alpha blending mixer behavior to make it compare the 2 sinks ? Or is there any explanation on how does it behave ?
Thank you
