14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
11 years agoHi Maik,
--- Quote Start --- I first have to start the jtag_server.tcl and after that I can use the jtag_client.tcl to access the JTAG to Avalon Master Bridge in my FPGA design, right? --- Quote End --- Yes. I'm pretty sure I made the client as simple as possible, i.e., if the server was not there it does not keep retrying the connection. You could easily add retry functionality, but I would recommend putting a delay in between retries. --- Quote Start --- And in order to get the server connected to the desired device on my JTAG Chain, I have to edit the jtag_open function and use device 2 instead of 0, right? --- Quote End --- The indexing starts from 0, and since you want to access the second device, you will want index 1. --- Quote Start --- After that I should just be able to access the avalon slaves via JTAG in my FPGA with the jtag_client software, right? --- Quote End --- Yes, that sounds correct. Cheers, Dave
