14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
11 years ago --- Quote Start --- Quick question: I've read your nice tutorial with great interest. But I did not find any discussion relating to practical bandwidth. On a DE0-nano board, would this avalon/usb blaster interface support an average rate of 2 MB/s from board to host? --- Quote End --- Sure, I've got lots of documents ... https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html The JTAG interface performance is documented in altera_jtag_to_avalon_analysis.pdf The performance is only about 600kB/s. You can use an FTDI device, check out ftdi.pdf (60MB/s for their HS devices) and ftdi_spi.pdf (2MB/s = 16Mbps serial data rate ... might be a bit fast). Take a read of those docs, and ask questions. Cheers, Dave
