14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years agoThank you very much for this tutorial. It got me pretty far. However, I did this in Quartus II 13.0 sp1 and there are some differences, two of which result in errors. I didn't go through the SOPC Builder chapter since that tool isn't available anymore.
- There are 33 warnings, not 3, when generating the Verilog files in Qsys. These are all Warning: qsys_system: "No matching role found for rst_controller:reset_out:reset_req (reset_req)". According to support solution spr371633 (http://www.altera.com/support/kdb/solutions/spr371633.html), these can be ignored.
- The logic element counts are different (e.g. 1106 at the top level, not 1058). I suppose Altera changed the library components.
- The Quartus II Handbook is different (e.g. the system console commands in table 10-3 mentioned in section 5.1 is on pages 10-9 through 10-11 of version 13.0 of the handbook).
- When compiling the simulations, the vlog command's -L argument that worked for me is libraries/altera_avalon_vip_pkgs_lib, not qsys_system_bfm_master.
- $TUTORIAL/hdl/qsys_system/scripts/sim.tcl contains the above error.
