14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years ago --- Quote Start --- Thanks! When was this function introduced (which Quartus release?)? I doubt that it will be faster at the JTAG layer (since the JTAG traces show that master_read/write_memory are as efficient as possible), but at least it saves Tcl performing binary->string and string->binary conversions. --- Quote End --- It was first introduced in ACDS 12.1 I think. Tcl is actually pretty good at conversions providing you use the right data structures. Where master_read_to_file and write_from_file really win is that they can do overlapped I/O (starting the second transfer while the hardware is processing the first one). For big transfers this hides the latency of the transfer and leads to a big performance improvement. Out of interest, which tool are you using for your JTAG tracing?
