14 years agoTutorial: Using the USB-Blaster as an SOPC/Qsys Avalon-MM master
Hi all, I've put together a tutorial on how to use the Altera JTAG-to-Avalon-MM master and Altera Verification IP Avalon-MM BFM Master under both SOPC builder and Qsys. http://www.ovro.cal...
13 years ago --- Quote Start --- Another question I have is the following: On page 37 I read the sentences: This would mean that the program won’t run in my quartus 10.1 version? Do you have a solution for this? --- Quote End --- Of course :) Read the source code (jtag_server.tcl) ...
# SystemConsole (prior to Quartus 11.1sp1) # # * There is no support for fileevent, so SystemConsole# has to busy loop on one client at a time.# # * If the client closes its connection cleanly via# client_close, then the socket generates an EOF# and the server will wait for the next client.# # * However, if the client disconnection is not cleanm,# eg., the client uses exit or ctrl-C to exit, then# the server does not receive an eof, and it remains# blocked on the dead client connection. New clients,# will not be handled!# # In constrast, when the server is run under# quartus_stp, the server log indicates that a ctrl-C# from a client quartus_stp generates an # 'empty command' followed by 'disconnected'#
puts "Handle the client via a blocked read on the socket"
while {!} {
client_handler $client
Note that this applies to SystemConsole, whereas quartus_stp (another tool) works fine. --- Quote Start --- For example is it possible to split this up? Meaning, if I install also quartus 11.1sp1 and run this tcl server/client program from a 11.1sp1 quartus_sh terminal, can I then still communicate to my sopc system generated in quartus 10.1? --- Quote End --- Yes, you can use a newer version of Quartus to communicate with the design after it has been downloaded. The JTAG protocol has not changed between Quartus versions. Cheers, Dave
