14 years agoTSEMAC SW reset bit never cleared CIII+KSZ9021GQ
Hi! I have my board with CYCIII + 2 PHY KSZ9021GQ. During debugging web_server under NIOS i have error out "TSEMAC SW reset bit never cleared!". And correspondingly does not start web...
14 years agoSomething wrong with the attachments, but anyway, the problem is somewhere in the software then. You should read out PHY registers and check for real values, because the driver could possibly read wrong values if the setup is not correct.
