14 years agoTSEMAC SW reset bit never cleared CIII+KSZ9021GQ
Hi! I have my board with CYCIII + 2 PHY KSZ9021GQ. During debugging web_server under NIOS i have error out "TSEMAC SW reset bit never cleared!". And correspondingly does not start web...
14 years ago --- Quote Start --- Are You sure You're reading the correct registers? Also I see that signaltap shows reset signal down, which indicates, that the system has hardware reset, rather than software reset. --- Quote End --- In Triple Speed Ethernet User Guide.pdf: https://www.alteraforum.com/forum/attachment.php?attachmentid=5152 What is logical level for this signal in TSE 0 or 1? Reset in qsys https://www.alteraforum.com/forum/attachment.php?attachmentid=5154 This signal from pin with pull-up resistor.
