15 years agoTSE with UDP without NIOS
Hello, i'm currently working on an implementation of a triple-speed-ethernet core, with use of a 1 Gbit Ethernet Interface, i use the SGMII interface to a phy. I have implemented the design of ...
15 years agoTake a look at this page: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example
There are hardware blocks that implement UDP as well as a light weight flow control/checking scheme. It's not exactly what you are looking for but it should give you some ideas.
