13 years agotse transmission get hanged in TCP protocal
Hello,everyone!
I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here: stratixiii_3sl150_dev_tse_sgmii_v1.zip (http://www.alteraforum.com/forum/attachment.php?attachmentid=1233&d=1246537769), the mode is "10/100/1000mac wtih 1000 base -x/sgmii"(1000Mbps & full Duplex mode). When using this design, the simple socket sever exmaple works well. Afterward, I changed the software design to test the stability of the connection, in TCP protocal. I use my Stratix III board as server, and my laptop as client. And made a for loop in both end to send and receive data: stratix iii, receive 1, send 2; laptop, send 1, receive 2. So, if the connection is stable, the loop will never be stop. But practically, the loop get hanged after some time, and I don't know why. Should it be a hardware problem(timing problem) or I do not write the software code right? Can anyone help me please?
