14 years agotse transmission get hanged in TCP protocal
Hello,everyone! I want to transfer data between my laptop(the OS is windows XP) and my Stratix III 3sl150 board through ethernet wire. I'm using the hardware and software design found here...
14 years agoHere is my changed simple_socket_sever.c
# include <stdio.h>
# include <string.h>
# include <ctype.h>
# include "includes.h"
# include "simple_socket_server.h"
# include "alt_error_handler.h"
# include "ipport.h"
# include "tcpport.h"
void sss_reset_connection(SSSConn* conn)
memset(conn, 0, sizeof(SSSConn));
conn->fd = -1;
conn->state = READY;
conn->rx_wr_pos = conn->rx_buffer;
conn->rx_rd_pos = conn->rx_buffer;
return;
void sss_handle_accept(int listen_socket, SSSConn* conn)
int socket, len;
struct sockaddr_in incoming_addr;
alt_u8 sendBuf;
alt_u8 *send_ptr = sendBuf;
len = sizeof(incoming_addr);
if ((conn)->fd == -1)
if((socket=accept(listen_socket,(struct sockaddr*)&incoming_addr,&len))<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,
" accept failed");
else
(conn)->fd = socket;
//sss_send_menu(conn);
send_ptr += sprintf(send_ptr,"Connected OK!\n\r");
send_ptr += sprintf(send_ptr,inet_ntoa(incoming_addr.sin_addr));
send_ptr += sprintf(send_ptr,"\n\r");
send(conn->fd, sendBuf, send_ptr-sendBuf, 0);
printf(" accepted connection request from %s\n",
else
printf(" rejected connection request from %s\n",
return;
void sss_handle_receive(SSSConn* conn)
char Buf;
memset(Buf,0,10);
//OSTimeDlyHMSM(0,0,1,0);
recv(conn->fd,Buf,2,0);
printf("%s\nrecieved OK!\n\n",Buf);
send(conn->fd,"2",2,0);
printf("2 sent OK!\n\n");
return;
void SSSSimpleSocketServerTask()
int fd_listen, max_socket;
struct sockaddr_in addr;
static SSSConn conn;
fd_set readfds;
if ((fd_listen = socket(AF_INET, SOCK_STREAM, 0)) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Socket creation failed");
addr.sin_family = AF_INET;
addr.sin_port = htons(SSS_PORT); //SSS_PORT=30 (simple_socket_server.h)
addr.sin_addr.s_addr = INADDR_ANY;
if ((bind(fd_listen,(struct sockaddr *)&addr,sizeof(addr))) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Bind failed");
if ((listen(fd_listen,1)) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE," Listen failed");
sss_reset_connection(&conn);
printf(" Simple Socket Server listening on port %d\n", SSS_PORT);
int cnt=0;
sss_handle_accept(fd_listen, &conn);
while(1)
sss_handle_receive(&conn);
printf("cnt=%d\n\n",++cnt);
} /* while(1) */
