15 years agoTSE-SGDMA something wrong
Hi all, I'm working on a custom board with nios2 + tse (10/100/1000) + DDR sdram... I'm trying to use a driver for triple speed eth under u-boot...the driver has been already tested on an altera...
15 years agoHi,
I created a SDC file for the PHY DP83848C some time ago. Maybe this file helps you out a little bit. Like I understood it is necessary to create the TX and RX Clock in the SDC. After that you have to define which Pins are synchronus to these Clocks.
