15 years agoTSE-SGDMA something wrong
Hi all, I'm working on a custom board with nios2 + tse (10/100/1000) + DDR sdram... I'm trying to use a driver for triple speed eth under u-boot...the driver has been already tested on an altera...
15 years agoOk...the problem is PHY clock....with the over mentioned change now I usually see the complete packet without any problem....anyway sometimes the error comes back again...not in the head (first byte) but in the tail (last byte) especially with big packets....
Now I understand that problem is there...it only need to correctly center phy clock.... Daixiwen and the others....which is the best way to regenerate this clock??? Thanx Carlo
