15 years agoTSE-SGDMA something wrong
Hi all, I'm working on a custom board with nios2 + tse (10/100/1000) + DDR sdram... I'm trying to use a driver for triple speed eth under u-boot...the driver has been already tested on an altera...
15 years agoHi Daixiwen..thanx for you reply....now I'm enabling loopback on mac to check problems with phy....
Phy is a more than standard DP83848C (that I've already on the demo and is working well)..interface is MII..I don't think that more than a reset and autoneg enable is needed...(anyway I see link going up correctly...) I have some doubt on the clock constraint...I don't remember but someone told me that the sdc automatically generated for tse doesn't constraint the 25 mhz input clock....am I wrong?? The only problem I can think about is a timing violation... Any idea??? Carlo
