16 years agoTSE or SGDMA related problem with concurrent tx and rx
Hi, Premise: I don't know if this problem is actually related to tse or sgdma; maybe even to Nios tse driver, although I don't think so. I'm sending and receiving Ethernet packets using t...
16 years agoThat's strange... could it be noise going from the tx line to the rx line?
You could put some signaltap probes on the MII interface (between the MAC and the PHY) to see exactly what is sent and receive, and compare them. That way you'll know if the problem is inside the TSE MAC or further out.
