15 years agoTSE memory usage
Happy new year, everybody! when I check resource usage in my design, I get the following readout: http://i51.tinypic.com/dm7cc2.gif Do I understand correctly, this means the TSE is w...
15 years agoThe latter two, especially Auto RAM Replacement On, are On by default and generally a good thing, as it only tries to put larger inferred RAMs into the memory blocks. If you're worred about RAM usage, it's probably worth looking at the RAM usage before and after and comparing. Note that this is the global setting, but can be applied to differently to any sub-hierarchies. Just right click on the hierarchy in the Project Navigator, Locate -> Assignment Editor, and make the assignment there.
