11 years agoTse mac
I am using ALTERA tripple speed ethernet ip core.My question is:-If rx_section_empty has crossed its threshold value and not coming down,will TSE MAC keep on sending pause frames ?????
11 years agoDid you build the MAC with internal FIFOs? If yes then I believe the MAC will continue to send XOFF pause frames spaced according to the holdoff_quant register. But I could be wrong about that.
I use the MAC with external FIFOs and use the xoff_gen and xon_gen pins to control pause frames manually. I monitor the Rx FIFO level myself and maintain my own timer for when to send another XOFF frame. I personally like having that control, plus easier to debug if things aren't working.
