17 years agotse_mac with dp83848 phy in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC.Currently I have this problem: ...
15 years ago"DHCP timed out, going back to default IP address(es)"
is does not matter,you could not be troubled by this,you only to set the MAC address by yourself,if the PC can ping,there is nothing to bother~then you can use hyperterninal of pc to view application layer transmition.
