17 years agotse_mac with dp83848 phy in MII interface
Hi I am trying to make a design with a triple speed ethernet MAC from Altera work. I am using a National DP83848 PHY and the small 10/100 version of the MAC.Currently I have this problem: ...
17 years agoYou should install something like Wireshark on your PC to see what is sent and received on the Ethernet link. Then use some SignalTap probes on the MII interface to see if the packets are correctly sent/received.
