14 years agoTSE_MAC and Timing Constraints
Hi Guys, I'm using 2x DE2-115s with my own Ethernet design (RGMII) and i'm suspecting i'm getting timing issues. I have no real idea on how to set up constraints and i'm just trying to patch s...
14 years agoYou don't want to include source files. You can include only header files.
The log shows that software setup is successful, so if ethernet doesn't work it may be fallowing problems: - bad pinout. e.g. wrong connection to the phy. check pin planner. - bad timing. check timequest timing analyzer. - bad reset polarities. - bad clocks.
