14 years agoTSE_MAC and Timing Constraints
Hi Guys, I'm using 2x DE2-115s with my own Ethernet design (RGMII) and i'm suspecting i'm getting timing issues. I have no real idea on how to set up constraints and i'm just trying to patch s...
14 years agoRGMII is not the default configuration used by the TSE driver. You have to add a file in the NIOS code (SW) to force the driver to set RGMII. I cannot retrieve the details so fast but the solution is somewhere in the forum.
Can you describe what's your problem? What are you able to verify and what not? Do you have an output console to show?
