14 years agoTSE_MAC and Timing Constraints
Hi Guys, I'm using 2x DE2-115s with my own Ethernet design (RGMII) and i'm suspecting i'm getting timing issues. I have no real idea on how to set up constraints and i'm just trying to patch s...
14 years agoGraphically is a little hard. I've tried to get the RTL viewr to filter from my pins. Attached is a PNG and an XPS in a zip. Both are the same, hopefully they are readable for you.
If your after specifics or you want me to do a series of RTL images i will. phy: Marvell 88E1111-CAA1 My actual connected signals are ALL are prefixed with "ENET0_": inputs: RX_CLK RX_DV RX_DATA[3..0] outputs: TX_DATA[3..0] TX_EN RST_N MDC GTX_CLK
