16 years agoTse Loopback Problem
Hi All, i'm trying to port u-boot on a custom board. I follow the nioswiki guide to build u-boot.bin and the bootloader started quickly...but it seems impossible to use ethernet. My demo (db...
16 years agoHi all again,
I solved the previous problem...i had not DMA transfer because descriptors were not allocated in descriptor memory area... Now I have this problem...from u-boot I can ping my PC but only the first time...when I try another ping debug traces show that RX descriptors stay busy till the timeout...even after SWRESET... Why RX descriptors cannot be resetted??? I forget...the driver I'm using is altera_tse.c under /u-boot/drivers/net in the version present in the latest distribution from the nioswiki... Any idea will be well accepted..;) Thanks
