11 years agoTSE IP usage
1. i want to use TSE for my design.i am using Quartusii version15 on which i found that the Ip core can be accessed in two ways. first one is by adding the IP from IP catalog on the right side of the...
11 years agoI'd recommend using QSYS if you are doing a NIOS design. Otherwise just use the IP catalog.
