15 years ago
TSE IP issue when downloading software application on NIOSII
I have a Stratix3 DSP development Kit based on EP3SL150F1152C2N FPGA. I use the Triple Speed Ethernet MegaCore ( 10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS). When I load the design in the FPGA -> OK .
But when I load the "simple socket server" software application or other software applications I have this error message : "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused".
It's strange because there were two weeks I load the"simple socket server" without any error. I didn't make any modifications between this two weeks. Is it possible that FPGA is damaged? Or else ?
I know it could be the "reset" signal of Nios2 but it is not. When I use the Triple speed Ethernet IP but without the "10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS" (for example 10/100/1000 Ethernet MAC) I can download software applications on NIOS2.
:confused::confused::confused:
If you have any question , don't hesitate.
Jeremy.
    Can you send me your standard design or a link to download it please ?
    Jeremy.
    Thank you.
    Indeed, It's not the same design (V8.0 is different from V9.0) but it doesn't work. I have the same error message. It's strange.
    Jeremy.
    If you still can't communicate with the Nios CPU with the .sof file compiled by Altera for the kit, then it means that you have a hardware problem on the kit itself. You should contact your distributor to see if they can do anything.
    I think the same. "My support" said the same also.
    Anyway, thank for your help.
    Jeremy.
