15 years agoTSE IP issue when downloading software application on NIOSII
Hi, I have a Stratix3 DSP development Kit based on EP3SL150F1152C2N FPGA. I use the Triple Speed Ethernet MegaCore ( 10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS). When I load the des...
15 years agoIf you still can't communicate with the Nios CPU with the .sof file compiled by Altera for the kit, then it means that you have a hardware problem on the kit itself. You should contact your distributor to see if they can do anything.
