15 years agoTSE IP issue when downloading software application on NIOSII
Hi, I have a Stratix3 DSP development Kit based on EP3SL150F1152C2N FPGA. I use the Triple Speed Ethernet MegaCore ( 10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS). When I load the des...
15 years agoI don't think we are talking about the same reference design. The design "stratixIII_3sl150_dev_niosII_standard" distributed with the kit already has everything and uses a RGMII interface. You don't have to assign any pins or do anything with it, not even compile it. Just take the .sof, use the .ptf for your software and try it. That way we can know if the problems comes from the hardware or four design.
