15 years agoTSE IP issue when downloading software application on NIOSII
Hi, I have a Stratix3 DSP development Kit based on EP3SL150F1152C2N FPGA. I use the Triple Speed Ethernet MegaCore ( 10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS). When I load the des...
15 years agoI use the reference design and I have the same with the CPU. Hower, if I don't assign the pins for enet_rx_p and for enet_tx_p I can run software on NIOSII. This design use the TSE configured to 10/100/1000Mb Ethernet MAC with 1000 Base-X/SGMII PCS.
I will test the others configuration of TSE. Thank you for your help. Jeremy.
