15 years agoTSE IP issue when downloading software application on NIOSII
Hi, I have a Stratix3 DSP development Kit based on EP3SL150F1152C2N FPGA. I use the Triple Speed Ethernet MegaCore ( 10/100/1000Mb Ethernet MAC with 1000 base-X/SGMII PCS). When I load the des...
15 years agoHi Daixiwen,
Yes. This error message (...FAILED...) appeared in the begining of the transfert of the sofware. But now, the transfert is OK and I have not this error message. Yesterday I discovered that if I don't use TSE (of course in SOPC builder), I can run software on niosII (and I don't have the error message above). If I use TSE and I don't assign the pins for enet_rx_p (that's to say : pin AA33) and for enet_tx_p(n) (PIN_W28) I can run software on NIOSII. If I use TSE and I assign the pins for enet_rx_p and for enet_tx_p(n) I have the error message above. Do you have an idea ? (The TSE above was configured to 10/100/1000Mb Ethernet MAC with 1000 Base-X/SGMII PCS). Other question : Do you have an example of design which use the 10/100/1000Mb Ethernet MAC (how to configure it, how to use it and connect it with the PHY MARVELL 88E1111) ? I read TSE MegaCore User Guide but I am a little confused with the different configurations. However I think 10/100/1000Mb Ethernet MAC coud be a good solution. What do you think about that ? Best Regards,
