13 years agotse ip core communicate with pc
hi, I instantiate the tse ip core with configuration of 10,100/1000Mb mac and RGMII interface in my project to communicate with pc,then initialize the register space of mac with the recommended ini...
13 years ago --- Quote Start --- Yes it is those clocks that you need to check. As for the rx signals on the RGMII side, you should see activity on those when the PHY receives a packet. Are you using the Altera drivers? Could you show the exact output you get on the console? --- Quote End --- sorry,what do you mean the Altera drivers? I have checked the clocks of clk(50mhz),ff_tx_clk(125mhz) and ff_rx_clk(125mhz) which are woring normally! But the mac still can't reset properly.I will show you the signaltapII results in attachments for you.
