13 years agotse ip core communicate with pc
hi, I instantiate the tse ip core with configuration of 10,100/1000Mb mac and RGMII interface in my project to communicate with pc,then initialize the register space of mac with the recommended ini...
13 years agoYes it is those clocks that you need to check. As for the rx signals on the RGMII side, you should see activity on those when the PHY receives a packet.
Are you using the Altera drivers? Could you show the exact output you get on the console?
