11 years agoTSE in SGMII Mode with external FIFO and PLL for PCS Ref Clock
Hi everybody, I try to use the Altera TSE in SGMII Mode with external FIFO. My board is a SoCKit. I need a 125 MHz signal for the pcs_ref_clk and want to keep it simple and do not change the SI533...
11 years agoThanks for your reply.
Yes, the SoCKit has a Cyclone V on it. Maybe it is because I am very new to Quartus: What do you mean by "use a PLL on the same side of the device as the transceiver"? Is there a way to use a certain PLL? It says that I am using 1/15 PLLs, so this is not a limitation of PLLs but maybe a limitation of paths? I can not find a value about clock control blocks. Well, I need to say that I maybe miss a important part and why the title says "with external FIFO": If I use the internal FIFO, it works with a PLL. In the near future I want to use multiport TSE that is why I am not using internal FIFO anymore. To summarize:
internal FIFO: hsmc_ref_clk => pcs_ref_clk OK (but wrong frequency)
hsmc_ref_clk => PLL => pcs_ref_clk OK
external FIFO: hsmc_ref_clk => pcs_ref_clk OK (but wrong frequency)
hsmc_ref_clk => PLL => pcs_ref_clk Error seen in the first post
The only combination which is not working is the one I need :D
